Shrinkwrap-wise coating without style module on photogrammetry model
- July 15, 2015
- 1 reply
- 2196 views
Hallo,
I have a 3d model of a pair of glasses frame, obtained with photogrammetry with Autodesk 123D (I took photos and then the software converts them into a .obj 3D model) and loaded in Creo as a .obj model. The model is made by (three) Facet Features, and due to the imprecision of the methiod unfortunately they do not form a closed 3D (there is a gash in the lens frame).
Since I have to make a 3D printing of them, I want to make a coating on it just like for example the shrinkwrap.
- This is to, first of all, close up the model in order to make it printable.
- Also, I would like the coating to be curvilineal (something like a "surface-spline" between points), and not squared like the Facet Features.
The problem is that the shrinkwrap function is greyed out and furthermore I do not have the style/restyle module license so I cannot even try to do something with it.
Would it be possible to do something like that with basic license?
I enclose the .obj model of the glasses frame.
thanks
bye bye
