Sketch Feature Tools WF5
  • November 4, 2014
  • 15 replies
  • 5505 views
Why is Sketch Feature Tools greyed out in WF5????
There seems to be something "wrong" with the design intent here. IF you are creating a hole there should already be an axis. IF you are creating a cylindrical surface, yxiou would need to use the Geometry Point to create an axis.
Mike Locascio
wfalco16-PearlAuthor
I am creating an oblong slot. I think problem solved. Thanks.
I think that I could get it to work. IF you have to, you can create an axis in the part. There are several "workarounds" for this type of problem.
Mike Locascio
Wayne-O,
Yes, I am pretty sure that would be a relatively easy axis to create. Good Luck!
Mike Locascio
tx
