Sketched feature as UDF
  • July 19, 2011
  • 716 views
Hello
Is it possible to have a sketched revolve feature as a UDF that only uses a surface and an axis for placement?
I do not want to use a sketched hole because it does not give me the flexibility I need..
Joe
Incredibly, old revolved UDF's created with the previous
"datum-on-the-fly" sketch plane, still can be used with only a surface
and axis selection.... They seem to work 90% of the time....
I'm afraid at a minimum, a sketch plane and orientation reference will
be required to create the revolved section and will be prompted for.
GE Healthcare Technologies
Clinical Systems
Monitoring Solutions
Eric R. Slotty
Mechanical Designer
8200 W. Tower Avenue
Milwaukee, WI 53223
