Stress analyze
  • February 13, 2012
  • 2 replies
  • 1991 views
I need to do a stress analyze of a hook feature in a plastic material in SI units.
But I don't have the material properties file for my material: Sabic Cycoloy C2100HF.
I do have a full datasheet for the material, but some of the properties are not mentioned.
Which are minimum properties to be in a material file do do a stress analyze?
YOUNG_MODULUS =
POISSON_RATIO =
SHEAR_MODULUS =
MASS_DENSITY =
THERMAL_EXPANSION_COEFFICIENT =
THERM_EXPANSION_REF_TEMPERATURE =
STRUCTURAL_DAMPING_COEFFICIENT =
STRESS_LIMIT_FOR_TENSION =
STRESS_LIMIT_FOR_COMPRESSION =
STRESS_LIMIT_FOR_SHEAR =
THERMAL_CONDUCTIVITY =
EMISSIVITY =
SPECIFIC_HEAT =
HARDNESS =
CONDITION =
INITIAL_BEND_Y_FACTOR =
BEND_TABLE =
PRO_UNIT_MASS =
PRO_UNIT_LENGTH =
Plastics typically don't specify Young's mod. Flexural mod and tensile mod are usually provided. I've used flex mod in the past with good success and I worked with Cycoloy (or PC-ABS equivalents) a lot (it's good stuff). I'd input flex mod for Young's and .3 for poisson's unless you can find that. That's all you should need to run.
