surfaces copy
  • March 30, 2010
  • 4 replies
  • 1102 views
I was looking different manners to copy a surface from a part to an other one.
With ctrl-C + ctrl-V method, I just can copy a curve from 1st to 2nd part.
When I select a surface, ProE tell me it's not possible.
I'm shure I do this a long time ago.
Is there an option to change ?
There is a tutorial from e-cognition that show difference between Ctrl-C and copy geom method so it should be possible.
GB
GB,
I just tested this on Pro-E WF 3.0. To copy from one part file to another part file, insert both parts into an assembly file. Copy the surfaces (ctrl-C) from the source part file (1st part), than activate (RMB) the target part file (2nd part) and paste (ctrl-v) the surfaces into the second part file. This proceedure is for Pro-E users that do not have AAX (Advanced Assembly Extension) module.
I do not remember if there is another way to copy the surfaces to second part without using an intermediary assembly.
Chris Thompson
www.appianwaytech.com
In Reply to georges bon:
GB
You can use INSERT, SHARED GEOMETRY, COPY GEOMETRY....
You can deselect the PUBLISH FEATURE icon to just select the surfaces you need.
I believe you need AAX for this to work.
Rui
On 30.03.
I have a special config file I call merge.pro for times when Pro/E says I can't have an external reference. Here are the contents:
allow_ref_scope_change YES
default_ext_ref_scope ALL
default_object_scope_setting ALL
default_object_invalid_refs COPY
ignore_all_ref_scope_settings YES
model_allow_ref_scope_change YES
scope_invalid_refs COPY
Semi-educated guess...
Instead of trying to paste a selected quilt into a different model, have you tried to Ctrl-C > Ctrl-V in the same model to create a Copy Feature and then copy the FEATURE from "model 1" to "model 2"?
Haven't tried it today, but seem to remember something similar in the past...
-Nate
