Swept blend, importing sections from datasheet (.txt/.xml)
I am trying to modell a foil with variable cross-section. I have the start and the end, and so far I have managed to convert them between xml, txt, dxf - and in turn get them as sketches using the import file and "use edge" tools.
What I dont seem to understand is how to make ProE fuse these into a single foil. As far as I know "swept blend" should work, but I cant find a way to get proE to use the finished sketches. And if I try to import the profiles while sketching in SB I dont get the same options that I used earlier.
I Guess this is pretty basic, but I just cant get my head around it. All help appreciated, thanks.
