Tolerance Does Not Round Properly
I have a dimension, with decimal places set to 2 and the config truncates trailing 0s, (MM[INCH])of 200 +10/0 [7.87 +.39/0]. When I change the decimal places from 2 to 1, my dimension becomes 200 +10/-0 [7.9 +.3/-0]. Shouldn't the tolerance of the 7.9 round to +.4/-0? I have seen this happen on other dimensions of metric parts, is there a config setting we need to fix or is this a problem with Pro?
