Using PTC_WM_REVISION:D in a drawing format
If I usePTC_WM_REVISION:D in a format it will not work on new drawing that have not yet been saved. It will prompt for the value because it doesn't yet have the parameter in the drawing until it is saved. I know I can use a template as a work around for new drawings but is there a better way that anyone has found? I would prefer not to have to reapply the format either.
Thanks in advance!
