what material file is being used?
All,
I have several thousand files that I want to be able to replace the material file. Without opening each file, is there a way to figure out what material file is being used for each part. I am using WF 3 M160 and ProI 3.4 M050. The material parameter is not designated, so I can’t see material information in Pro/I
Madhav Rao
