Why wont this model convert into a Sheet Metal part?
  • July 28, 2011
  • 0 replies
  • 712 views
Any Sheet Metal pro's out there? I'm attempting to model this Deutsch Strain Relief component WHDS-24-1. (PDF and PRO/E WF5 Model attached) Deutsch only had the pdf 2d print of it so I was trying to create the 3d model of it.
I started out initially trying to create it from scratch in sheet metal mode but I could not find a good way to create the intermidiate section of this part whereittransitions and tapers from one dia to another, so I switched back to standard part mode until I developed the intermidiate section of this part through surfacing then when I made the switch back to Sheet Metal mode it failed to convert.
Any suggestions or help as to why it wont convert?
