Automatic Enforced File Save when Referenced Files Modified?
I have a MathCad worksheet ("X.xmcd") that references another MathCad sheet ("Y.xmcd"). I am utilizing the ASCII contents of "X.xmcd", the file that lives on the disk. If I modify "Y.xmcd" and open "X.xmcd", I see the changed values of those variables that depend on the contents of "Y.xmcd". However, even if I "save" the file "X.xmcd" by clicking on the save icon (or using Cntrl-S), the date stamp on "X.xmcd" does not change nor does its contents. (That is, there is a discontinuity between what is on disk and what I am seeing on the screen.) I noticed that if I use a "save as" to the same filename it also does nothing. However, if I "save as" to a new file name, the contents in "X.xmcd" have now been updated to reflect what I'm seeing in the GUI.
What is the easiest/fastest/safest method for me to enforce an automatic "save" on file "X.xmcd" that updates the contents on the disk whenever file "Y.xmcd" changes? I would prefer a batch version of any solution.
Scott
