Calculating the intersection point on a graph
- 1 reply
- 1652 views
- Translate All
I need to plot the intersection and return it as a value.
I have lines to show minimum and ideal operating temperatures but I would like to find the cut-off temps for each of the proposed AC-DCs.
I have a graph that has the output derating so the line isn't a simple ab2+c so I have to use a function.
I would like to know the maximum operating temperature of the multiple power supplies. Based on a Wdc1(Tempamb).
I tried using solve but this doesn't appear to work on functions. as the derating is not constant across the full operation range.
see the example of the function I am using below.
What is the best operation to achieve this? I have attached the worksheet for reference
I'm using MathCAD Prime 8
