Copy & Paste to Word Document
  • October 17, 2013
  • 5 replies
  • 8434 views
Hi All,
Does MathCAD Prime 3 support copy and paste to a Word file? Prime 2 did not support this.
Regadrs,
LS
Yes, but unfortunately only bitmaps, no reasonable vector format. So its not really useful.
lsingh-21-VisitorAuthor
Werner,
That means it is the same as it was with MCAD 15?
NO! Mathcad 15 was NOT bitmap,
See attached a Wordfile showing the difference. try to resize, etc.
We can copy Prime's remarks into Word as text.
Valery,
How about copying integration, theta, etc. symbols into Word? I am more interested in copying "exactly" from MCAD Prime to Word.
Its ok, even if I am not able to edit in Word, I want to make sure that I can copy exactly.
LS
Try do this with/thru pdf-format
Thanks Werner. The copy and paste from Prime 3 is not clear and blurry, whereas MCAD 15 is very clear. So no proper improvement in MCAD Prime 3 then. I guess I will stick to MCAD 15. Thanks Valery.
Have you tried doing "Paste Special" from Word?
Actually the paste feature is not available in Word in this case. I tried with Word 2007 and 2010, and windows vista and 7.
With MC 15, word 2007 or 2010, it works.
With MC Prime 1,2,3 I don't know
