Define equals bug? (Mathcad 14)
  • July 21, 2011
  • 4 replies
  • 5041 views
Try the following:
Maybe I am understanding incorrectly, but nothing after the = sign should affect the definition of "This", but it does. If I format the result by putting mW for the units on the far right of the definition it changes the value of "This" from mW to W (i.e. it multiplies the values of the definition by 1000).
In fact if I put W*A on the far right (on the defition line) it does not change the value of "This". However if I put W*mA on the far right it again multiplies the definition of "This" by 1000.
I searched in the old Collab and this section, but did not find anything.
Am I missing something here?
Can you upload the worksheet?
Mike
Mathcad 15 output.
Mathcad Prime output
Which version of 14 are you using?
All is correct in Mathcad 15!
Fizix1-VisitorAuthor
I am using Mathcad 14.0.0.163.
Here is an upload of a newly created worksheet.
I have not migrated to 15 yet, because last I knew it was not compatible with MS Office 2010.
Download and install the latest service release for version 14. The problem will go away.
