Dramatic failure of PTC Mathcad
  • August 30, 2010
  • 4119 views
Hard to believe !
I have posted an update of "OdesolveMinerr" a minute ago.
It does not show in this community
Will it show, don't know ?
If a collab posts an update,
it should show immediately. If it does not show the update,
how collabs or visitors will benefit.
What I'm saying is that at this very moment, my 16 pages
of "tool box" appear to me in the PTC recycle bin.
... my updated work sheets shows, but does not show !!!
It shows in "Usage", but that's what all collabs have systematically rejected. When opening PTC community, click on Mathcad and there it should show "Mathcad ", Mathcad inclusive of all conferences. Actually it is exlusive
Dan, can you understand this renewed point ?
You don't seem to have listen to what more collabs have explained from the very beginning. I can make my own soup out of this messy "facebook". Just have to plug a new discussion OdesolveMinerr update If it makes sense to you, it does not to me. An update is new stuff, if new stuff does not show, how can visitors get it ? In the "London Times ? in "La Presse" ? in "Drummondville Herald" ? "Petaoushnock Gazette" ?
Jean, did you mark your post as being updated? This will bump the thread and indicate that changes were made to the original post. No need to start a new thread on the same topic.
Yes, it did add my update note but it didn't show anything as soon as posted and not after quitting and logging again because it did put the update in the wrong place . Do you see it in "Mathcad" ? NO . So, that's what I'm saying: If I post a work sheet it must show, if it does not, what is the point to have an "attachment". Your concept of a collaboratory is based on too many bits and tricks that conflict in the logic it is implemented. And what about the tags that in the case of an update are the same tags, so which tag your logic links to ? Do you understand what I'm saying, if next year I update what is posted today, who is going to capture the update if it does not show ? Other collabs had the same comment(s) [in different words], hide and seek in the sand.
