Feb 25, 2014 5:40 PM UTC
FIND command with limited variable range
Hello everyone,
I'm here again to ask for your kindly help!
I need to find a variable of an equation but this variable must be in a range.
For example:
x:=10..20
Given
2x²+3x=30
I mean, x must be between 10 and 20.
Is there anyway to do this?
Thank!!
Werner_EAnswer
Feb 26, 2014 6:48 PM UTC
Get rid of the symbolic evaluation of rebits_x (or at least change the 0 to something else, look at the error message) so you file will calculate without error.
That's why I was using the "given find" function, to figure the best answer.
And thats the point - which question?? Not in terms of your application but in terms of math expressions and functions. What is a constant value, what should be changed (and how), which quantitity is dependend on which changing variable (make it a function), what is the goal, the equation you want to be fulfilled at the end.
Feb 25, 2014 5:44 PM UTC
You can add a constraint in the solve block like 10<x<20.
But "find()" will fail as both solutions of your equation are outside that region.
MaxGomes1-VisitorAuthor
Feb 26, 2014 12:07 PM UTC
There is problem yet:
Take a look, I found passo_x.
________________________________
Then limited the range:
It doesn't accept, what is the right way to declare it?
Thanks!
Feb 26, 2014 12:21 PM UTC
Why not use the normal numeric evaluation instead of the symbolic one?
We just had a thread where again a constraint like yours made problems with symbolic evaluation.
I don't see from your pics how the various variables are derived, but the symbolics will nut simply take the saved values but will follow their definitions. Did tyou traced back the error?
Anyway, numerics should be good enough in that case, I think. If for some reason you need symbolics (from what I see I coudn't image why) you may try the symbolic "solve" in combination with the appropriate "assume".
Feb 26, 2014 12:24 PM UTC
Ok, I will try.
