Gas work and pressure
- August 28, 2011
- 3 replies
- 4211 views
Hi, I want to simulate gas work and expansion in cylinder - piston system. The enery nor temperature is not constant and I am in trouble putting gas work into differential equation. Please look at the file (Mathcad 15). I extracted only the question, leaving the diff equs out.
The work done depends on the position of the piston and pressure, which also depends on the position and so on. Quite a mess.
