How to calculate more than 18 floating point digits ?
  • December 17, 2012
  • 2544 views
I am trying to evaluate something but Mathcad 14 doesn't show it because it is very small, how can I view small numbers that are after 18th floating point digit ?
Go to the Format menu. Select Result..., Tolerance, and set Zero threshold to a large number (maximum possible is 307).
Alan
Or so:
It is very useful! Why?!
yeet1-VisitorAuthor
Not exactly.
Shows the same value for each matrix element but I know that the elements should vary at 30th floating point or so ?
