Mathcad solve block interation
  • January 30, 2013
  • 1140 views
Really easy problem that I can not figure out how to have the solve block solve it by iteration. Any help is appreciated.
I'd like the solve block to return 20 values of Z corresponding to each value of X in the matrix.
You can not use indexed assignment in a solve block. If you really would need that kind of iteration, you should turn the solve block into a function.
Another way would be to put the definition of the range variable above the solve block and also delete the assignment Z:=50 and put instead Z[i:=50 above the solve block (which has no guess values at all now). In the solve block write X for X[i and at the end write Z:=Find(Z) and you are done.
In your case I cannot understand why you would use a solve block as direct assignment would be the method of choice.
See attached.
