taking inverse laplace
- December 22, 2010
- 1 reply
- 5070 views
I want to take inverse laplace of an transfer fucntion that I have generated by analysis of a circuit and I am having difficulty with it. Please see the attached file. It is saved in MC13. The parameters x1, x2, x3 are initial conditions of caps and they are real and positive numbers.
The second equation takes the inverse laplace once numbers assigned to x1, x2, x3. But I want to calculate the inverse laplace in equation 3 as a function of x1, x2, x3 as parameters. Then I will replace x1, x2, x3 with some equations once the inverse laplace is found.
How can I calculate the inverse laplace of equation (1) having x1, x2, x3 as parameters in the solution?
Thanks.
Mark.
