How do you hide construction lines in drawing
  • November 21, 2016
  • 16726 views
I need to have construction lines to get intersections and dimension placements on a drawing but I can't seem to find how this is hidden.
I do however have a few solid lines and arcs that I would want displayed on the drawing.
Is there a way to filter by construction entities and blank these on a drawing?
Best answer by MartinHanak
you published picture of your drawing. Unfortunately I do not understand how construction lines were created. Are they draft entities created in the drawing ? If this is true, then hiding them using layer is the only way I know.
MH
can you upload some example data and pictures showing what you want to hide ?
MH
pimm15-MoonstoneAuthor
Martin
Here is a view of the type of entities I would like to hide.  See the type arrowed in green.
Since my post I have discovered that I can make a new layer to the specified entity type and specifically hide this.
Is there an easier way?  I would prefer to select all of a type and just right click hide, but that isn't possible that I can see.
MH
