Inheritance link, part to part, meaning of different icons in Model Tree
  • June 6, 2025
  • 2 replies
  • 1097 views
Hi all
I'm using inheritance .prt to .prt model links.
I'm getting 3 different icons shown in the model tree.
and
Can someone explain the different meanings of these 3 variants?
I already checked the information in Model Tree Icon List - PTC Community
Thanks a lot in advance
Pius
We are using Creo Paramterics 8.0.4.0,
Best answer by Pius
Oh, yes!
Here in I found a datum plane which was of no use.
Deleted it and the Icon turned back to "Vanilla".
Many thanks.
if you can ask the same question to PTC Support.
EDIT:
https://support.ptc.com/help/creo/creo_pma/r12/usascii/#page/assembly/asm/About_Inheritance_Features.html#
Thank you for asking about those glyphs. Those indeed pertain to Inheritance Features and carry a meaning. The best ressource here has to be the Help Center.
First
This is a vanilla Inheritance feature
This is an Inheritance feature with Varied Items
<will get back to you>
FYI Varied Items can be set accessing that menu (here when the Inheritance Feature is created) :
or RMB the existing Inheritance feature > Varied Items
Pius14-AlexandriteAuthor
Hello remy
This sounds promising.
Is there an option  to get rid of the "varied items" symbol?
It may have happen that I selected this just for fun but without any need.
Finally about the Pause glyph, it looks like something related to Windchill which is out of my technical area.
According to that article : https://www.ptc.com/en/support/article/CS243120
And the article here : https://www.ptc.com/en/support/article/CS58783 tells that the glyph is about some frozen state of a feature and I'm not totally sure if this state is relevant with Standalone Creo Parametric.
