Looking for a specific type of Rotational Equation Curve
  • May 15, 2024
  • 5 replies
  • 4684 views
I have successfully used a specifically sized flat Equation curve in my die designs.  I have on a number of occasions however needed to use the same radius and spacing around a rotation which to this point have been very fudgy.
Below is the equation that I have been using.
This results in a curve like the following.
Would it be possible to make an equation curve to the below shape?
The spacing would be the same as with the top example but I would somehow need to be able to define a center or slope.  Can this be done?
Best answer by kdirth
If you are looking to follow a true radius, I agree with @KenFarley  that a cylindrical equation may work well:
You may also want to consider using construction geometry to get the desired path:  Create a curve for the sine wave to follow. Create a surface sweep using relations to create the sine wave around the curve.  Use/copy edge of surface.
kdirth
Are you looking for something like this:
pimm15-MoonstoneAuthor
Kdirth:  This is a very nice arithmetic style curve but unfortunately not what I'm trying to achieve.
What I am looking for is a curve that doesn't have any 3 dimensional depth.  The rotation that I am looking for above would be similar to taking a cross sectional slice of a Recess Peanut Butter Cup.  (The rotation I have been looking for would be on the same 2D axis.)
kdirth
kdirth21-Topaz IAnswer
tbraxton
You are looking to superimpose a periodic function (sine/cosine) on a circle? Something that would look like this?
Tbraxton:
Yes; in the same orientation of what you show.  The challenge would be in keeping the inside radii the same as the outside radii and also maintaining a uniform spacing.
tbraxton
This is possible to do in Creo using curve from equation functionality. The parametric equation (cartesian coordinates) of the picture I posted above is:
KenFarley
Have you looked into using cylindrical equations (r, theta, z) instead of cartesian? It might make the mathematics more straightforward.
tbraxton
This gives you direct control of parameters in a single feature. Getting the syntax of the equations is the only tricky part to this. Amplitude, frequency and radial offset of the zero-amplitude circle are defined in the equations shown here in Creo syntax. You should be able to cut/paste this into your curve from equation feature definition. Make sure to set the domain of t from 0 to 360 (degrees) to cover a complete circle. 0-180 for half circle.
x=(1.5+0.5*sin(20*t))*cos(t)
y=(1.5+0.5*sin(20*t))*sin(t)
z=0
Curve from equation in cartesian system:
tbraxton
StephenW
Y'all are rattling off formula's and all I can think about is how much I like reese's peanut butter cups! Nothing else matters!
Yes; that must explain why I just had some.  The power of suggestion.
I can't say it has made me understand this any better but at least I'm happy.
