3-Newcomer
September 17, 2024
Profile Rib feature not generating beyond a narrow width
  • September 17, 2024
  • 3 replies
  • 2051 views
I am trying to create a part from the solidworks model mania series.
The part includes an S shaped rib feature.
The feature fails to generate beyond this very narrow thickness
What am I missing?\
I am using creo parametric educational edition
I have included a link to a YouTube video I uploaded showing the exact process I used to create this feature.
https://youtu.be/xmp79topSuU
I'm also including a link to the model mania part drawing for reference
I am new to creo so any input helps 🙂
Best answer by tbraxton
It is possible to build this using a profile rib to match the drawing reference. Do not include the rounds/fillets in the section for the rib. See the video for how to build it. As general rule do not include fillets/rounds in Creo sketches unless absolutely necessary to design intent.
Dale_Rosema
What's the OD of the boss?
3-Newcomer
September 17, 2024
52mm OD, 32mm ID
Dale_Rosema
You can't add a 60 mm rib to a 52mm boss. It doesn't know what to do with the extra 8 mm.
kdirth
It appears creo is having trouble connecting it to the boss.  Try extending the line beyond the silhouette edge.
3-Newcomer
September 17, 2024
Thank you for the response!
I tried it but it still isn't generating
kdirth
I tried the profile rib in 7.0 and 11.0 with the same results.  I would suggest using an extrude rather than the profile rib, since Creo is not able to follow the curvature of the boss.
tbraxton
tbraxton22-Sapphire IIAnswer
