Render Window - Black Background
  • February 23, 2010
  • 8144 views
Hi, I have barely touched on rendering in ProE, but I like the way the product looks 'smoother' after a simple render using the 'render window' button. This would be good for screenshots, but after rendering the window, the product is fine, but the background is black. How do i get a white background?
Under render control set the settings to high or maximum, if you leave it at draft you will get a black background. maybe that what you are referring to.
Back to rendering Pick a part or assy. Veiw(top tool bar) => check(pick) 'Realtime Rendering' This will bring up the default scene Veiw => model setup => render setup This will bring up the render setup menu In Room, 'render room check box' check(pick). If 'render room check box' is not checked in the render menu you will get a black background. You can pick draft, high, or maximum, for the quality. Any more ways I can add to your confusion Let me know........but this should get rid of the black background problem.
