Non linear speed control
  • January 31, 2022
  • 2 replies
  • 6691 views
Hi community , Once again I call on you .
my problem:
I have a mechanism with a non-linear movement
in input, I have a linear displacement, and in output I have an angular displacement
this displacement follows a behavior curve
I want to drive the input with a motor, so here is my problem.
I want to find a max speed value of motor to reach a given angular position. But also that time is linear
that is to say, if I want to go from 0 degrees to 60 degrees (for example) what will be my lowest linear displacement time (constant speed value at output), and what will be my motor control curve
the solution I found is cut the curve with linear parts,but I don't really like it because it's DIY
I don't see the way to get there, maybe with the derivative
If someone has an idea
I don't see your attempt in the file you sent.
As far as I understand you are looking for a function
alpha -> speed in rev/s
Can you show the calculations necessary and the result for one or two example angles?
XDN14-AlexandriteAuthor
I'm having trouble explaining myself because I don't speak the language well.
example
if i want to move Alpha =60deg ( row 61 in alpha matrix)
the imput stroke is  32.355mm (row 61 in s matrix)
For 1 motor rev  the imput stroke is :0.069mm
Capture d’écran 2022-01-31 130442.jpgFinally, i need to make 32.355mm
and so my motor must do 32.355/0.069 = 468.913 rev
max motor rev speed :0.287 rev/s but is non linear
if i cut the curve, and if that I admit a linear part from 0deg to 10deg
for 10 deg  , imput is 2.682mm
2.682/0.069=38.87rev
time is :135.436s    for travel 0 to 10deg
and now i assume my curve is linear from 10deg to 60deg
imput stroke 60deg =32.355mm
imput stroke 10deg = 2.682mm
32.355-2.682 = 29.673mm
29.673/0.069= 430.043rev
430.043/0.287=1498s
I don't know if I'm clear, but I want to come to this:
find max speed motor for each target value (row of alpha matrix) for a linear travel time
i want to move 0deg to 60deg with lineartravel, for this I can see that my motor must turn slowly at the beginning, then as quickly as possible at the end
the max speed end is 0.287rev/s so it is this value which is measured to evaluate the speeds at small angles
sorry for these confusing explanations, I think there may be a way with the derivative, but I can't find anything
yes, you have undestand !
"Seeing the kinematics seems to make it clearer for me.
The goal is to move the orange part to a specific angle position as fast as possible but with constant speed (of the orange part) which means variable speed of the nut"
yes
"The relationship between the motor speed and the speed of the nut is linear and the max speed of the motor is about 0,287 rev/s.
Is this correct so far?"
yes
"Is the desired movement always from the zero degree position to a certain angle or can the starting point be different to zero? Lets say something like "move the orange part from 70° position to 25° position"
yes
For the rest I may have made typing errors.
in my sheet:
the screw is : Ø6x2
for one rev, the nut travel 2mm thanks to the helical connection
the max speed motor is 500rpm
the max speed output gearbox is  0.287rev/s (with mechanical ratio i=29)
v.vis_vss33 = 0.575 mm/s  mean the nut velocity translation
ttokoro
As Fred Kohlhepp already mentioned, using polyfitc function, you can use to do next step mathematically.
Tokoro.
t.t.
