I have configured RMB from File->Options->Shortcut Menu.
I have configured toolkit commnads on RMB for ModelTree.
Now I want to export this configuration and save it for the installation.
Can anyone help here?
I have tried following thing:
"load_ui_customization_run_dir yes" is entered in config.pro
a "creo_parametric_customization.ui" is in the start directory.
but when I install "config.pro" and .ui file on other machine then it does not show my configurations.
location of .ui file was wrong 😄
I moved it to folder which has .pro file and it is working fine.
