Third party js library in mashup
  • August 13, 2025
  • 2 replies
  • 1802 views
Hi everyone,
i have this third party software which i would like to connect with thingworx so my first test is that i have app.js, index.html and this javascript library which worked well locally in my computer and now i would like to do same thing in mashup.
i am using valueDisplay widget in mashup and would like to render it in mashup. now my html is rendered properly and i can see it in mashup but i feel like i am unable to get app.js file and library js file in html.. I have uploaded all three files in the file repository.. i feel i am not accessing it right with repo link ....
Anyone has some feedback, i would be happy to hear..
https://github.com/dymosoftware/dymo-connect-framework?tab=readme-ov-file
<!doctype html>
<html>
<head>
 <meta charset="utf-8" />
 <title>DYMO Connect Framework – ThingWorx</title>
 <style>
 body { font-family: system-ui, Arial, sans-serif; margin: 24px; }
 button { margin-right: 8px; }
 #log { white-space: pre-wrap; font-family: ui-monospace, Consolas, monospace; }
 #preview { max-height: 180px; display: block; margin-top: 12px; }
 </style>
</head>
<body>
 <h2>DYMO Connect Framework – Test</h2>
 <div>
 <button id="btnEnv">Check Environment</button>
 <button id="btnList">List Printers</button>
 <button id="btnPreview">Render Preview</button>
 <button id="btnPrint">Print</button>
 </div>
 <img id="preview" alt="Label preview will appear here" />
 <h3>Log</h3>
 <div id="log"></div>
 <!-- External scripts only -->
 <script src="/Thingworx/FileRepositories/TestBench.Repository/downLoadPicturesWithTimeRange/dymo.connect.framework.js"></script>
 <script src="/Thingworx/FileRepositories/TestBench.Repository/downLoadPicturesWithTimeRange/app.js"></script>
</body>
</html>
My vs code implementation is
index.html
<!doctype html>
<html>
<head>
 <title>DYMO Connect Framework – Local Test</title>
 <style>
 </style>
</head>
<body>
 <div>
 </div>
 <h3>Log</h3>
 <script src="./dymo.connect.framework.js"></script>
 <script src="./app.js"></script>
</body>
</html>
app.js
const $ = (sel) => document.querySelector(sel);
const log = (msg) => { console.log(msg); $('#log').textContent += msg + '\n'; };
(async function main() {
 try {
 await dymo.label.framework.init();
 log('Framework initialized');
 $('#btnEnv').addEventListener('click', () => {
 try {
 const env = dymo.label.framework.checkEnvironment();
 log('Environment:\n' + JSON.stringify(env, null, 2));
 } catch (e) { log('checkEnvironment error: ' + e); }
 $('#btnList').addEventListener('click', async () => {
 try {
 const printers = await dymo.label.framework.getPrinters();
 log('Printers:\n' + JSON.stringify(printers, null, 2));
 } catch (e) { log('getPrinters error: ' + e); }
 // A tiny sample label (Address 30252); adjust to match your label stock
 const sampleLabelXml = `
<DieCutLabel Version="8.0" Units="twips">
 <PaperOrientation>Landscape</PaperOrientation>
 <Id>Address</Id>
 <PaperName>30252 Address</PaperName>
 <DrawCommands/>
 <ObjectInfo>
 <TextObject>
 <Name>TEXT</Name>
 <ForeColor Alpha="255" Red="0" Green="0" Blue="0"/>
 <BackColor Alpha="0" Red="255" Green="255" Blue="255"/>
 <LinkedObjectName/>
 <Rotation>Rotation0</Rotation>
 <IsMirrored>False</IsMirrored>
 <IsVariable>True</IsVariable>
 <Text>DYMO Test\nHello World</Text>
 <HorizontalAlignment>Center</HorizontalAlignment>
 <VerticalAlignment>Middle</VerticalAlignment>
 <TextFitMode>AlwaysFit</TextFitMode>
 </TextObject>
 <Bounds X="180" Y="120" Width="3060" Height="540"/>
 </ObjectInfo>
</DieCutLabel>`.trim();
 let label = null;
 $('#btnPreview').addEventListener('click', async () => {
 try {
 label = dymo.label.framework.openLabelXml(sampleLabelXml);
 const png = await dymo.label.framework.renderLabel(sampleLabelXml, null, null);
 $('#preview').src='data&colon;image/png;base64,' + png;
 log('Preview rendered');
 } catch (e) { log('renderLabel error: ' + e); }
 $('#btnPrint').addEventListener('click', async () => {
 try {
 if (!label) label = dymo.label.framework.openLabelXml(sampleLabelXml);
 if (!printers.length) return log('No DYMO printers found');
 const printerName = printers[0].name;
 await dymo.label.framework.printLabel(printerName, null, sampleLabelXml, null);
 log('Printed on: ' + printerName);
 } catch (e) { log('printLabel error: ' + e); }
 } catch (e) {
 log('Framework init failed. Is DYMO Connect running? ' + e);
Best answer by MA8731174
Thingworx Extension for Software Dymo Connect Framework:-
https://github.com/Jamal8548/twx_dymo_extension
Rocko
The sentence "i am using valueDisplay widget in mashup and would like to render it in mashup" does not make sense to me.
There are two ways to render HTML: HTMLAreaWidget or WebFrame.
WebFrame is just an IFrame to some other location.
HTMLAreaWidget will not run javascript. It has a limited support for HTML tags and attributes, this was recently discussed in the forum.
You will have to use a custom widget rendering a script tag to add the library (and app.js) to the page.
MA873117416-PearlAuthor
Thanks for your reply. ValueDisplay widget let you also render your html in mashup. you can select property valueFormat and then can select there HTML. as you can see below
yes about htmlAreaWidget and WebFrame you are right. But just curious about valueDisplay widget that why it did not work ..may be also because of limited support.... i will give it a shot with custom widget in mashup.
Rocko
Oh, the HTML render function, didn't think of that.
Maybe check the mashup debug console and the browser console to see
-what is finally rendered
-if the files are loading (F12->Network)
-which errors are thrown
18-Opal
August 14, 2025
You probably want to wrap it in a ThingWorx UI extension, since you now have a working example you made for opening/closing popups.
You can expose those DYMO methods like checkEnvironment, getPrinters, printLabel and renderLabel through your widget's Services -- this way you can make it all ThingWorx-native and implement configurable logic based on Expressions, ThingWorx backend services, etc., instead of hacking HTML.
/ Constantine
Thanks for your suggestion and that was also my thought and i am pretty close now to finish it. I have one query regarding it. I have a .dymo label file stored in a ThingWorx File Repository. To read it, I created the following service:
let result = Things["Dummy.Repository"].LoadText({ path: "/downLoadPicturesWithTimeRange/label.dymo" });
The service returns the file content as a string.
When I directly paste this string content into my widget property (type = String), everything works fine.
However, when I bind the service output to the same property (also of type String), the property value in my widget becomes undefined in the logs.
Am I missing something in the binding or service configuration that could explain this behavior?
This service which returns this string of file get executed when onmashup load and output i have also bind to one textfield just to test that either it returns string expected output. everything is fine but still it makes this property undefined in logs which i bind it.
ah! i found out same issue created in the past and it has resolved my issue
https://community.ptc.com/t5/ThingWorx-Developers/How-can-I-use-binded-data-on-Custom-Widget/td-p/527537
