Getting this error while accessing the Thingworx composer: "openID Connect Provider error: server_error" "Error occured while performing an attribute lookup"
  • May 24, 2017
  • 1430 views
I am getting this error when I am trying to access my Thingworx Composer on server:
Can you provide more insights about it:
​Is it some kind of ​Internal Server Error?
Why does it happen?
and
What actions can I perform to remove this error?
-Thanks & Regards,
Shashank
Shashank, are you running custom authenticator? Is this a fresh installation or have you upgraded? Where's your ThingWorx running? You may want to check the tomcat and thingworx application log for more detail on this error.
sm-311-VisitorAuthor
Hi Sushant,
Thanks for raising those questions, the issue occured due to the custom SSO authenticator only.
-Regards,
Shashank
