google map not load in View Mashup
  • September 21, 2017
  • 12 replies
  • 6541 views
I use 30 days hosted trial, google map widget could not load normally in View Mashup, Error Message like "Oops! Something went worng... See the JavaScript  console for technical details.".  How could I get this right?
schen-711-VisitorAuthor
It's right to download google widget extension from makerplace, and modify metadata.xml, and import extension?
Hi Sandra, yes it OK to do that to update the key. In fact you can refer to this article guiding you on how to update the key in the metadata.xml API Keys and the Google Map Widget in ThingWorx
Hope this'd help.
Hi Sushant, thank you for your help, google map can be viewed normally.
Glad it helped
