How to add a dynamically created thing in a network programmatically ?
  • December 7, 2016
  • 2 replies
  • 2774 views
I am creating a thing using code and then I want to add that thing into a network using code.Any idea how to do it ?
Hi Digital, could you please help me understand further on your requirement of adding to network? Which network are you referring to?
You can add your thing to the network using the AddConnection service:
var params = {
            to: "ChildThingName" /* STRING */,
            connectionType: "Contains" /* STRING */
        // no return
        Networks["NetworkName"].AddConnection(params);
Edit: If it is a top-level connection, leave the from parameter as undefined.
done111-VisitorAuthor
Thanks James it was really helpful !
