How to add Combobox and Checkbox in Grid columns?
  • June 2, 2014
  • 2414 views
Can anyone please let me know how to add Combobox and Checkbox in Grid columns?
Raj
    Sorry Raj, this functionality does not exist in the Grid. It is for Read Only purposes.
    rajgs1-VisitorAuthor
    Thanks for the clarification. Is there any other control serving the purpose ? I wanted to add check box/combo in table same as that of  the added entity list in the home page of Thingworx.
    The list widget has Combo Box functionality, just toggle view property. Please note, for a combo box, the widget must be in a non-responsive area, so add a panel if you are working in a responsive mashup.
    A check box widget of course provides the check box functionality.
    If you had to have a Grid type of setup, you could use a Repeater mashup and basically build a mashup to represent a row and use the repeater to repeat that row for as many times as needed.
