How to design a custom widget using Java Source Code ?
I am trying to build a custom widget and I create a UI using JavaFX. Now how do I implement my java source code for ThingWorx Mashup Widget design?
I use Thingworx-eclipse-plugin and ThingWorx-Extensions-SDK to build the extension. My java application perfectly run in my computer, but when I use this extension in Mashup no design appears there.
