How to get absolute path of ThingWorx Repository ?
  • December 8, 2015
  • 4 replies
  • 7781 views
         I need absolute path of ThingWorx repository in one of service, how i can get it in service? As of now I have added hard coded value for it (C:\\ThingworxStorage\\repository\\).
Also is there any inbuilt function to get file separator for underlying operating system. I have added hard coded value for it (fileSeparator=”\\”).
    Ramesh,
    There is no service function to get an absolute path or file separator.  We do not want to expose any underlying OS or file system structure via Thingworx as in some cases it is considered a potential security issue.  All access is therefore controlled via Thingworx and its security structure,
    Could anyone please guide me to identify the absolute path of repository of ThingWorx instance running on cloud like (ge2-xxx.cloud.thingworx.com)...
    22-Sapphire I
    March 1, 2016
    What is the use case? Why would you need the absolute path?
    You can get paths to files in the FileRepository using the GetFileListingWithLinks service for example, those would be URLs
    Thanks for prompt reply Pai... The use case is :
    1. I wanted to upload files to ThingWorx cloud repository.
    2. Later I wanted to download those from my android mobile , or in my raspberry pi gateway.
    My guess is , if I can obtain the absolute path - i can use rest service to download the files.
    If you build a Server Side Extension ( java ) you can easily get it with:
    ApplicationContext.getInstance().getRepositoryDirectory()
    Thanks.....
