Issue when completing Weather Applications with Raspberry Pi tutorial
  • April 8, 2016
  • 3093 views
In part 3 of the Weather Applications with Raspberry Pi tutorial when I try to create a release jar I get an error that I cannot seem to solve. Any insight into the solution will help. The tutorial is located here, Weather Applications with Raspberry Pi | ThingWorx
The error is listed below:
C:\Users\rkell_000>cd C:\temperature-thing\temperature-thing
C:\temperature-thing\temperature-thing>mvn package
[INFO] Scanning for projects...
[WARNING]
[WARNING] Some problems were encountered while building the effective model for com.ptcmanaged.thingworx:temperature-thing:jar:1.0-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-deploy-plugin is missing. @ line 112, column 21
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building temperature-thing 1.0-SNAPSHOT
Downloading: https://maker01.ptcmanaged.com/mvnrepo/com/thingworxs/thingworx-common/5.0.0/thingworx-common-5.0.0.pom
Downloading: https://repo.maven.apache.org/maven2/com/thingworxs/thingworx-common/5.0.0/thingworx-common-5.0.0.pom
[INFO] BUILD FAILURE
[INFO] Total time: 23.074 s
[INFO] Finished at: 2016-04-08T15:57:09-04:00
[INFO] Final Memory: 12M/244M
[ERROR] Failed to execute goal on project temperature-thing: Could not resolve dependencies for project com.ptcmanaged.thingworx:temperature-thing:jar:1.0-SNAPSHOT: Failed to collect dependencies at com.thingworxs:thingworx-common:jar:5.0.0: Failed to read artifact descriptor for com.thingworxs:thingworx-common:jar:5.0.0: Could not transfer artifact com.thingworxs:thingworx-common:pom:5.0.0 from/to ptc-managed-services-public (https://maker01.ptcmanaged.com/mvnrepo): Connect to maker01.ptcmanaged.com:443 [maker01.ptcmanaged.com/54.173.81.52] failed: Connection timed out: connect -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
Hi Ryan,
Please check out this post for the error you are getting in your mvn package command.
https://community.thingworx.com/message/4268#4268
Let me know if you need help with anything else,
Thank you,
Veronica
7-Bedrock
July 7, 2017
Hello Veronica,
Is there a more recent location of the maven repository than http://maker01.cloud.thingworx.com/mvnrepo
The old and the new location are both not available.
Or can you provide the required .jar file.
Eric
