Modifying Org Login Page using services
  • October 2, 2017
  • 2 replies
  • 1497 views
I am using services to create and edit organizations in a mashup and want to know if it is possible to edit the organizational login page via a service. I haven't been able to find anything useful under the organization services or the entity resource services.
Does anyone know of a way to do what you can do in the composer when you create an org, but doing it via services?
Jack Riely​: I believe there is no built in services available to update/modify organization details like we do it via composer. One reason is that Allowing Organization related changes has significant ripple to the ThingWorx platform UI and other dependent applications. We might consider additional functionally in our NextGen Composer to provide services to update/modify Organization changes.
-Durgesh
20-Turquoise
November 6, 2017
You can create Organizations, add members, Move organizationalunits, etc all via services. You cannot rename organizations.
