My remote thing is not getting connected, why?
  • January 11, 2016
  • 4 replies
  • 5872 views
I have added a remote thing, It was working til the previous day.BUt now its showing "isconnected" as "false" after connecting also.
What might be the reason behind this?
Check the code
Hi Supriya V,
Can you please post a screenshot of your Command Line output after running the jar file for temperature-thing-jar-with-dependencies along with the command for running it?
Thank you,
Veronica
Hi veronica,
is it possible to connect to more than one thing using same C SDK?
Hi Anup G Prasad,
Yes, it is possible, you just need to bind more than one Thing using this method :
  /* Bind our thing */
  twApi_BindThing(thingName);
You also need to separately register the properties you need for the Thing :
  /* Regsiter our properties */
   twApi_RegisterProperty(TW_THING, thingName, "Temperature", TW_NUMBER, NULL, "ALWAYS", 0, propertyHandler,NULL);
   twApi_RegisterProperty(TW_THING, thingName, "Humidity", TW_NUMBER, NULL, "ALWAYS", 0, propertyHandler,NULL);
Best regards,
Veronica
Are you connecting via an EMS or SDK?
@Ravi am connecting via c sdk
Hello Anup,
Can you please share with me the structures of progSets and progSets1?
Thank you,
Ciprian
Hi Ciprian,
progSet
tw_host=ge2-3611.cloud.thingworx.com
tw_port=80
AppKey=118e56a5-a714-432f-a4d2-5fb770d04824
ScanRate=2000
Name=RaspberryPi_C_11364156447720966
ComPortId=/dev/ttyAMA0
SimMode=true
PinConfig=pinConfig_rPi.json
Debug=false
progset1
tw_port=80
ScanRate=2000
Name=Am2302
SimMode=true
Debug=false
