Not able to deploy Thingworx post loading (bad) extension
  • April 28, 2015
  • 1209 views
Getting the following, how do I recover? Loaded a custom extension, must be something wrong with it that caused this.
INFO: Deploying web application archive F:\tomcat\webapps\Thingworx.war
java.lang.NullPointerException
        at com.thingworx.thingtemplates.ThingTemplate.getImplementations(ThingTe
mplate.java:1986)
        at com.thingworx.system.entities.ThingWorxEntityManager.initializeImplem
entationRelationshipsForEntity(ThingWorxEntityManager.java:257)
entationRelationships(ThingWorxEntityManager.java:269)
        at com.thingworx.system.ThingWorxServer.Initialize(ThingWorxServer.java:
158)
        at com.thingworx.system.ThingWorxBootstrapper.contextInitialized(ThingWo
rxBootstrapper.java:132)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContex
t.java:5016)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContex
t.java:5524)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:901)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:87
7)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:649)
        at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1081
    Vinay,
    Do you have an export of your entities and data? Is this an extension you developed?
    Yes. I can provide the extension zip, no data. It was just minor changes to the Hello extension, I realized that metadata.xml had an issue later. But what I would really like to do is to get it back up for the other work that I did on that instance.
