Resetting Repeaters / Grids to "Null"
Hey all,
The solution I'm currently developing, on ThingWorx 6.5, contains a textbox, repeaters and grid.
The textbox let me write down a string.
When that string is entered, services will be launch will get data to populate the repeaters and the grid.
Since those services are SQL Based, it might take some times to get the data from it.
The user, if he change the text will get another set of data, so the current repeaters / grid are staying with the data of the "old" string until the service are completed.
Would there be a way to set the repeaters and the grid to "null" / Or maybe a loading panel/widget that tells the user that the data is being requested ?
Frederik Grondin
