Use REST to external URL to update Thing property?
I am using Texas Instruments Sensortags as things. I want to model them as ThingWorx things.
I have an external cloud server that is storing properties of the sensors in the Sensortag.
I have a REST API that I can use to get these property values from this server. I can execute the API via curl or postman just fine. REST get commands are used.
I am looking for an example of use REST to set properties of the Sensortag modeled in ThingWorx. I have seen some examples when the REST calls are made to the Edge Micro Server (EMS). But I am not using EMS here.
Is it the same?
A code snippet would be much appreciated. Or a link to a ThingWorx document where this is discussed.
Jim
