WTreeTable Events
  • August 18, 2016
  • 2053 views
Hi Experts,
I was able to show data populated in WTreeTable.
Now, I want to trigger an event when I click on the leaf node.
I want to call a service, with the leaf-node name as the parameter to the service.
Can anyone help in doing this?
    Hello, I am not sure what you mean by WTreeTable. Is this from an extension of some kind?
    ses1-VisitorAuthor
    Yes Tori. Itz a part of Windchill extension.
    If my need can be served with TreeTable, then it is also fine if you put some guideline in it.
    Can you take a screenshot of where you are seeing this? I asked a member of the Windchill Connector team for guidance, and they still were not sure to what you are referring. Do you mean to say Tree Widget? That, I have heard of.
