Best Practice for sharing modified production assemblies?
The description doesn't really fully explain the request. An example:A user uses an existing production part or assembly as the basis for a layout or concept in a workspace. The object is at Released status in Windchill.He wants to share this with other users, but doesn’t want to iterate a standard object that may not actually get changed. How do you share this data with other Windchill users? Currently the user is saving to a network drive which defeats the purpose of having Windchill.
We could just check them in to Windchill at Prototype, for instance, and all would have access. If you do this, do you just
leave a dead-end design in the system for history? And if so, how do you ensure that the next person to attempt a new design based on that assembly goes back to the earlier Released iteration to work from and doesn’t accidentally pick up the incomplete prototype by using the default “Latest” at checkout?
If you do something similar, do you use Purge often to limit the buildup of unnecessary iterations?
