Complete Change Management Process in Windchill
- October 21, 2010
- 8 replies
- 4159 views
If your effectivity is immediate for failures or immediate recalls, then it will automatically set the resulting objects to obsolete or superceded.
Hopefully you get to this stage. There is a whole lot more with WTPart management business process to meet to most large aerospace company standards like Boeing,EADS, Lockhead Martin, Airbus, Northrop Grumman Corp, Bombardier, BAE, Mitsubishi,etc which follow most change management processes like CMII for each functional group. This is to ensure that thereis accountability and process is clear, concise and valid. Most contractors or vendors of these companies have to comply to their change process because for large mass production, the process must be efficient to cut cost down for the entire supply chain. A fit, form and function change or not has to be common knowledgeand iron clad.
Hopefully Windchill can mature to meet the needs of this standard change process in the aerospace industry for the past 30+ years.
