8-Gravel
May 7, 2010
ECR Change Classification in the ECN
  • May 7, 2010
  • 5 replies
  • 1322 views
I need to add a conditional to the ECN workflow that is dependent on the change classification of the ECR. Basically, if the ECR classification is equal to "Obsolete" then take this route, otherwise, take this route. I am struggling with the syntax and possibilities within the workflow editor. Any help would be appreciated.
James Little
8-Gravel
May 12, 2010
Anyone have any suggestions for this? I would really appreciate some help or insight.
In Reply to James Little:
James Little
Hi James
It is very straight forward.
1. Edit ECN workflow,
2. Add conditional router in appropriate place
a. Choose Conditional as Routing Type
b. Add Routing events within Routing Events pan
c. Under Routing Expression, find the ECR using API like QueryResult
result = QueryResult queryresult =
ChangeHelper2.service.getChangeRequest((wt.change2.WTChangeOrder2)primaryBus
inessObject), true);
d. From the queryresult get the ECR
e. Find ECR Classification
f. if (ecrClassification.equals("obsolete")) result =
"Obsolete_Route"; else result = "route2";
if you need any specific clarifications, please shoot me a line or give me a
call.
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect
973 216 0456(M); 973 324 2729(W); 866 908 6561(F)
Work Email: swamy.senthil@swasen.com
LinkedIn Profile:
8-Gravel
May 12, 2010
Thanks for the input. Let me try it on our development server and see
the results.
I appreciate your response.
James Little
Corning Cable Systems
CAD Administrator
Jeremiah 33:3 "Call to Me, and I will answer you, and show you great and
mighty things, which you do not know."
avillanueva
23-Emerald I
May 12, 2010
Here is my conditional:
if
(customization.workflow.GoodrichWorkflowProcessHelper.isValidAutoAccept(
(wt.change2.WTChangeRequest2)primaryBusinessObject))
ECCreator=customization.workflow.GoodrichWorkflowProcessHelper.getECRCre
ator((wt.change2.WTChangeRequest2)primaryBusinessObject);
ccbcDecision="Approve";
analysisComments="Auto-Accepted";
approvalDate=new
java.sql.Timestamp(System.currentTimeMillis());
com.ptc.windchill.pdmlink.change.server.impl.WorkflowProcessHelper.setTr
ack((wt.change2.WTChangeRequest2)primaryBusinessObject, "SIMPLE");
result="Accept";
else
ack((wt.change2.WTChangeRequest2)primaryBusinessObject, "COMPLEX");
result="Continue";
But the code you want is here (externalized):
public static boolean isValidAutoAccept(WTChangeRequest2 ecr) throws
WTException
Category category=ecr.getCategory();
//if we have an auto-acceptable category
if
((category==Category.toCategory("INITIAL_RELEASE"))||(category==Category
.toCategory("ENG_ERROR")))
//and the creator is part of the Product area team
(CONFIRMED)
ContainerTeamManaged containerteammanaged =
(ContainerTeamManaged)ecr.getContainer();
Enumeration enumeration =
((ContainerTeam)containerteammanaged.getContainerTeamReference().getObje
ct()).getMembers().elements();
while(enumeration.hasMoreElements())
WTPrincipalReference wtprincipalreference =
(WTPrincipalReference)enumeration.nextElement();
WTPrincipal wtprincipal =
(WTPrincipal)wtprincipalreference.getObject();
if(wtprincipal instanceof WTUser)
WTUser wtuser = (WTUser)wtprincipal;
if (wtuser.getName().equals(ecr.getCreatorName()))
return true;
return false;
James, this is the helper class that has all your business logic. Just add another method to it and call it from the workflow as suggested below.
