File Vault Size - MS OS - Copy File Issues
  • October 20, 2010
  • 0 replies
  • 1413 views
We have a single file vault among our 70 total vault on our production server where the limit configuration was turned off over a year ago. Since then it has been corrected but we still have an issue with the # of files in this vault. The vault with the issue is #42 of 70. Vaults 1-41 copied to the re-host server quickley. The copy timeframe on this vault appears to be +2 weeks. The vault is 111GB with over 1,480,000 files. In 12 hours we copied 1% of the files. Microsoft OS 32-bit moving to a MS OS 64-bit. The copy was executed from the 32-bit system. The obvious issue is this will become an issue during the Production Server upgrade to move these files in a weekends time we have for the upgrade.
I see two option but need to find a solution for both.
1 - Use a different method of copy other than Rich Copy for the data transfer that is more effecient.
Does anyone know a solution?
2 - Somehow in PDM divide the File Vault into Multiple File Vaults.
Does anyone know the long term affects of doing this?
