Intralink 3.4 Migration Test Server
  • August 1, 2012
  • 2 replies
  • 800 views
We are currently on Intralink 3.4 M062
I need to setup a test server for testing the migration to Intralink 10
Can I go from the base install of Intralink M012 to the Service Pack
M062 or do I have to install the earlier SP first?
Wow this is digging deep down into my memory but I thought you could install M020, then M060, then M062... I think. The "Read This First" or install guide will help you.
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image002.jpg@01CD6FD1.9B8ED6D0]
August 1, 2012
You can install M062 directly. It does not need any earlier version as a
base.
Jonathan Strayer
Johnson Controls
The views, opinions, and judgments expressed in this message are solely
those of the author. The message contents have not been reviewed or
approved by Johnson Controls.
