Modifying Revision sequence
When we were using Intralink 3.x we had a revision sequence that went from X0-X20,0,1,2,3...etc.
We have been using Intralink 9.1 since 9/09 and I have just discovered that we can only go as high as X10 before it increments to 0. I don't recall this being a limitation during migration and we obviously missed testing it..
I'm not sure we had any documents at rev X11 or higher, but today a user tried to revise to X11 and got an error message saying that the new revision did not exist or was not higher than the previous revision (X10)
Is there a way to update the revision sequence to add X11-X20 back in or is this a non-trivial task? It is the only sequence we have defined for documents.
I'm off to do some research..
