productview worker issue
  • July 20, 2010
  • 444 views
All,
lately, after migrating to pdmlink 9.1 m050, I'm having some issues with
publishing pro e files "on the fly" (meaning by the user - from
information window). once the user send the file for publishing the
worker failed to publish.
if I open the file manually, regen and create the viewable manually -
everything work just fine.
I have no issue with the "default" publishing (publish on check-in
operations).
did any of you cross similar issue ?
pdmlink 9.1 M050 on win2003 server 64bit
WF 5 M050 defined as the worker
Rami
On 7/20/2010 1:51 PM, Rami Noach wrote:
> All,
Rami,
Can you past the error message from the publisher monitor?
Once guess though is, did you set your auth.properties? Or possible
one of your queues is stopped.
Pretty hard to take a guess what is going on from the information you
supplied, so if you could send more detail that would be helpful
--Bob
> with publishing pro e files "on the fly" (meaning by the user - from
> operations).
> Rami
> -----End Original Message-----
