Releasing Problems in ProductPoint?
I am continually working on multiple projects at the same time and trying to document changes to systems that we have built and shipped. Currently Product Point will make you release every file that has been revised when you release upper level drawings. I would like Product Point to show me all the files that have changed but be able to select what models that are being released. This way I can control my revision levels and keep the revision level on the drawing consistant with the revision level within Product Point. How are you handling this issue or is this something that you would like to see changed within Product Point?
