Subscriptions to assignments
  • September 9, 2010
  • 0 replies
  • 401 views
Hi, in PDMlink 9.1 there are lots of things that you can "subscribe" on.
Meaning you will receive a mail any time a type of change you defined occurs on the object.
But there are things you can't subscribe on, such as : assignments. When you've a new assignment, there is no easy way to create a subscription on that.
You could reply that the event/workflow creating those assignments should be configured to send mails. But this is a server solution, I was searching for a client solution, that each user could configure (do I want to have mails or not, it will depend if I'm often in PDMLink or not).
Do any of you had the same problem/request and how did you solve that ?
Thanks in advance for your reply.
Xavier LEGER
CAD/DMU Support, Volvo Group
